Old Oct 22, 2006 | 02:20 PM
04Fire's Avatar
04Fire
Default Re: Please Help!! Head unit uninstall
Originally Posted by Eracer76
The radio you have should be held into its metal can/sleeve by 4 small phillips head screws.
To get to them, remove the face plate, then the trim ring, then you'll see the screws, two on each side, remove them and the radio should slide out of its sleeve.
Then if you need to, you can remove the sleeve by unbending the tabs that hold in.
I GOT IT! It was just as you said only I messed up. I overlooked a screw that was threaded. It took me almost an hour to get just that one screw out.
Thanks guys! You saved me a lot of time, I love this forum!
