Old Nov 17, 2025 | 04:44 PM
zip439's Avatar
zip439
Default Re: Rear CV axel replacement
You do not need to open the differential. That ring is spring steel and will collapse into a grove near the end of the splines. Just give the half shaft a sharp pull to collapse that ring as it is shaped like a "C". You can reuse the ring if the new half shaft you purchase doesn't come with a new ring. Chrysler has discontinued the ring for our axle.
