Re: "need Some Help" Top Will Not Work
Thanks for replaying
Yes the windows go down and up with the switch in the car (regular function) the do not go down when the D ring is disengaged from the windshield/frame.
The Latch Retainer Switch/Sensor was checked for continuity and voltage and both were correct and reading satisfactory, so this is not the problem
The fluid level of the hydraulics is at the MIN line - do you know the fluid used?
