gblack32
Well i have replaced both the hose and the conductor plate and am still having the exact same issue as before. Still no check engine light so I guess we are back to the throttle body or the pedal being bad. Very demoralizing
Hi,
I have a manual transmission so I wouldn't know if your symptoms could be caused by that or not. In my opinion, I would lean towards the the accelerator pedal. The electronics in it are probably on their way out.
Try testing the connection at the pedal. Make sure it's not loose or broken. Pull the connector and check the contacts for corrosion. Clean everything and put it back together. See if anything changes. At least it won't cost anything to try.
Good luck!
