Old Mar 24, 2004 | 02:31 PM
Jamikest's Avatar
Jamikest
Default
Update...
I did indeed read the very same in the owners manual. The manual is not very clear on this at all. After talking with tech line, I have come up with the following:
from tech line... "...some vehicles are equiped from the factory with the 'UConnect' system. This should be available through Mopar accesories for all other vehicles"
So- firstly.. UConnect is Chryslers hands free phone system. Works with any blue-tooth enabled cell-phone. Then the call is automatically routed through the stereo of the vehicle. Secondly- I did not find the current accessory catalog listing the CF as having UConnect available.. This does not mean it is not available yet. The catalog may have been printed before the system was available for the CF. I have not yet contacted Mopar Accessories to see if the kit is available for the CF.
From what tech line has said- if you have the UConnect system, the radio can be set up as described in the audio controls section of your manual. If not- you can get it through Mopar accessories (although I have not yet verified its availability).
Another note.. The Owners Manual I referred to was an older print. Tech line said newer copies will be more clear on the description of this system.
