Old Feb 4, 2026 | 02:40 PM
WTS's Avatar
WTS
Default Re: Interesting find
Google ain't much help, but getting the numbers off of that chip that's mounted there might help --
Google says-
This is a universal prototype printed circuit board (PCB) with a surface-mounted component, likely a CPU or MPU, attached to it. These boards are typically used for hobbyist or prototyping projects.
  • It is a double-sided board with plated through-holes for easy component mounting and soldering.
  • The component appears to be a processor, possibly a Freescale MPC860PZQ80D4 or similar chip.
  • The board is installed in an automotive application, likely as part of a custom electronic modification.
  • The component uses a Ball Grid Array (BGA) or similar package type, requiring specific soldering methods.
