Thread: Audio build
Old Feb 7, 2026 | 06:09 PM
Dasfarrar's Avatar
Dasfarrar
Default Audio build
I’ve gotten a little audio bug bite since I haven’t really done much since the mid 2000’s being the last real audio build and I wouldn’t really call this a competition system lol. So far I have done the front and yes of course the tweeters wire isn’t that long after the photo I ended up shorting it because I was test fitting ended up resoldered i had to dremel the tweet hole out just a smug bit and use some plastic weld so that the vibration from the road or sound wouldn’t move or fall.
front doors are skar T65
tweets are TWS-01 very minor adjustments
once I get a little more time I’ll post an update on the rear I’m sure I’ll will have to dremel the plastic.
I also have a 3d printed Double Din made the original one was 3d scanned and will be better fit and finished than the ones that I have saw so far. There also might be a chance of buying the 3d file so that you can print it as well.
