Old Feb 15, 2026 | 11:02 AM
  #65 (permalink)
zip439's Avatar
zip439
Default Re: Cylinder Misfire Help
Originally Posted by tlhayes580
This sounds like the same issue I am having . I also replaced MAF, Crank pos sensor. Then plugs, coils, and wires. Did you ever figure out issue? Contemplating a bonfire..... help please.
Any DTC ??
Did you check the EVAP solenoid? Take the line off that runs to the back of the car; Put a small vacuum on it. If you get gas you have found your problem.
