Old Feb 16, 2026 | 11:22 PM
M60A3Driver
Default Re: Seat power switches RHD
Originally Posted by fired
Hi guys,
Let me approach this a different way for your thoughts.
My car is a RHD srt6 roadster. It does have working height adjustment.
So, for ease of entry/exit I need to slide drivers seat back and forward each time I use the car.
The seat has no issues moving forwards with immediate response
However sliding back takes patience and some fiddling with slide switch before it does engage and go back.
Is there a clear fault that is easily identified here and straight forward to fix.
thanks again
It sounds like the contacts in the switch that slides the seat back could possibly be dirty or failing. The least expensive way to try and solve this would be to spray the switch with some contact cleaner and see if that changes anything.
If not, you might want to replace the switch. Just my opinion. Good luck!
