I am wondering if someone can give me some advice please, I live in the UK and have a 2005 Roadster with 52K miles on the clock which I am currently experiencing problems with, my spoiler does not retract, about a week ago I was giving the car a run, everything was performing as expected, no warning lights on or buzzers sounding, I pushed the car up over the 60 mph and the spoiler was activated, but looking in my rear view mirror I could see the spoiler had not been fully deployed, and when I stopped the spoiler did not retracted, again there were no warning lights on, or buzzers sounding, so I pressed the spoiler switch and the little red light in the middle of the switch begun flashing and the spoiler remained up.
I will add that the car is kept on our drive all year round with three tarpaulins over it, I have since pulled everything out of the boot and that is bone dry, so I am pretty sure it is not water ingress that has caused the problem, I have also checked the fuse boxes and all fuses are OK, but while playing around with various switches I thought I would lower the roof, I released the catch and the side windows went down, but then it stopped its cycle, after playing around with the switches nothing happened, so I disconnected the battery for a few minutes and then re-connected it, but nothing happened, no change, so I then locked the roof, then pressed the window lift switches and the windows went up, I have since driven the car, it goes fine, but the fault is still there, can you help me I would appreciate you feed back?
Ken
