Old Mar 19, 2026 | 08:25 PM
M60A3Driver
Default Re: Random No crank no start?
Originally Posted by Wazy300
Hey guys, ive been chasing a no crank issue for a few days and could use help before throwing more time/money at it.The
car was driving fine, parked it for about 30 minutes and when i went to start it back up, nothing no crank, no noise at all. Assumed starter or relay, however after confirming the relay was fine and replacing the starter (bench tested before installing it works), the only difference is now there's a slight hum sound, but still no start or crank. Ive been chasing it and have done as such so far
-Battery tested
-Starter wires seated properly
-replaced battery terminal clamps
- Used a test light and confirmed the starter works while installed and under load.
- And before you say RCM its already been resodered previously, and I'm getting a noise while trying to start, so i dont believe its this.
Hearing the hum i believe the starters engaging but not fully mabye low current? bad power delivery?
Im sorta just stumped any and all suggestions or tips are greatly appreciated.
How old is the battery?
You can search on how to check the manufacturer's actual date code on the battery case.
If it's over 3 years old, I would replace it. Without the enough power, the car will not start.
