Old Mar 30, 2026 | 07:54 PM
sofiawiayz's Avatar
sofiawiayz
Default Re: Windshield washer
To access the tank and pump for a leak inspection, start by ensuring the vehicle is parked on a flat surface and the engine is off. First, locate the access panel, which is usually found under the rear seat or in the trunk area. Remove any screws or fasteners holding it in place. If your vehicle doesn’t have an access panel, you may need to drop the fuel tank, which involves disconnecting the fuel lines and electrical connections. Once you have access to the pump and tank, visually https://tropical-casino.com/ inspect for any cracks, loose fittings, or wet spots that could indicate a leak. If you find any issues, it might be wise to replace the faulty components before reassembling everything.
