mistykup
I tried searching for replacement instructions for the seatbelts, but didn't come up with much. Has anyone replaced them that can guide me? Both sides have been eaten about 20%across from mice.
Thanks Friends!
I have a set of seat belts that you can have for the cost of shipping. I had a company redo my seat belts in a color. What I did was purchase a used seat, and they used those, and when I received the new ones, I changed them. I will say when they came, they were in a position where you had to be very careful, as they needed to put in a particular order. I have a PDF I found that shows me how to get them out and how to put them in.
I could email it to you. You will have to disconnect the battery, which is why I went with purchasing an extra set to make it easy. You will need to remove the trim at the back where the belt exits. At the bottom of the belt is bolted, and that is where the electrical connection for the seat belt is.
You can email me, and I will send you the PDF I have.
gonzalez@earthlink.net
Nelson
