Clovis
Hello, I purchased my 2006 Chrysler Crossfire Limited Coupe back in November and it’s been a lot. But the issue i’m having and needing assistance with is after a large rainstorm. My vehicle will turn perfectly fine, nothing out of the normal. But when i start driving and getting to 40mph, I feel that my car isn’t shifting gears automatically. The engine revs louder than normal and the RPM will continue to rise without the gear shift. It is an automatic. I’ve looked to troubleshoot the car and used an OBD2 Scanner and got 3 codes. P0301(Cylinder 1 Misfire) P0600 (Serial Communication Link) and P0128(Coolant Thermostat below regulating temp). While driving for no more than 10 minutes, a clear smoke started coming out of the hood of the car. I couldn’t determine the smell but it looked like steam. I opened the hood and also couldn’t tell where it was coming from. I let the car sit for a few days before checking again thinking it was possibly water. But i had the same issue with the smoke coming from the engine bay and will not go over 40 without that high RPM issue. Ive been looking all over the place, and I am hoping that I can get guidance as to where to start looking to resolve the problem, and/or maybe find someone in the SATX area that works with these vehicles. Any and all information is extremely useful.
You could borrow a Radiator Pressure Tester Kit from an auto store. That's what I used to find the leak on my Audi S4. I did not even need dye as you can hear and see where the leak is,
