Old May 10, 2026 | 02:21 PM
NWGACarGuy's Avatar
NWGACarGuy
Talking Re: Coolant line broke off
this is not a superior fix, this will eventually fail at an inopportune time. while some are still holding, most eventually leak/blow out past the brass threads in plastic. sure gooping some jb weld around it may help. i think i will eventually make up an aluminum reservoir
Correct me if I am wrong - but don't the OEM tanks ALL FAIL "eventually"? I can't imagine that there is an opportune time for either the OEM or the fix to fail. The fix is certainly less expensive than paying whatever the going rate is. And ask the SRT owners how superior an OEM tank is that is no longer available? Give me threaded brass and epoxy over a cheap plastic nipple any day.
