Old May 14, 2026 | 04:04 PM
GraphiteGhost
Default Re: limp mode nightmare
Who and where is the guy that did the work? If the same code is present, you may not have had to replace the Trans plate. Lets hope the TCM isn't physically damaged (water/corrosion) and the shift lever isn't damaged from a spilled beverage. Do the inspections Zip mentioned in post 2, and testing of the shifter in post 5 that Zip posted. Good luck!
