Old May 15, 2026 | 01:19 PM
Valk
Default Re: Phantom Shifter Bushings
Originally Posted by Americium
I have had my 6 speed slip out of 1st gear on occasion, it will do it if I don’t consciously make sure it’s fully in 1st when I take off. It will pop out with a big bang noise. I wonder if these bushing are a contributing factor? Did you have to pull the transmission to get them out? Or just lower it after removing the driveshaft? Replacing with poly sounds like a good idea.
I have had my 6 speed Roadster for 8 years and driven 54,000 miles and only have used 1rst gear when starting up hills or steep inclines
Starting in 2nd gear seems to work well and I have had no issues with the clutch and never needed to ride the clutch out slowly to start in 2nd gear
IMO 1rst gear is such a low gear it isn't really needed unless starting uphill
