Old May 24, 2026 | 06:26 PM
GraphiteGhost
Default Re: Oil Change Intervals
No need to get oil all over the place, many here use a vac pump (like the topsider) and slip the hose into the dipstick tube. This way everything is on top of the engine. Make sure when you replace the filter you put the top "o" ring in the correct slot, or you'll wind up with oil throughout the engine compartment. Just an FYI.
