Re: Can't Start - no Crank
I had same issue. You said you replaced the RCM. My mechanic put in a used RCM bought on eBay. It was bad also. Bought another one from a reputable seller and it worked. Are you able to pull codes? If it comes up P0410 (secondary air pump), it's almost always the RCM.
