Old Yesterday | 08:04 PM
jovoke's Avatar
jovoke
Default Re: Brighter headlight
Originally Posted by ZERACER
Can anyone recommend a brighter low beam headlight bulb for our Crossfires. Is there an LED can bus bulb we can use, similar to the plug and play options available for a Toyota Land Cruiser Lightbar? The older the headlights get the dimmer the low beam driving lights seem to get.
5:03 AMClaude responded: Yes, canbus compatible LED bulbs work for the Crossfire.Yes, canbus compatible LED bulbs work for the Crossfire. It uses an H7 bulb for low beams. Look for bulbs labeled "error free" or "canbus ready" such as Auxito H7 LED, Cougar Motor H7, or Fahren H7 Canbus LED. Some may still need a small canbus decoder adapter to prevent flickering or dash warning lights. Stick to 6000K or below for the best visibility. The dimming you are experiencing is normal for aging halogens and an LED swap will make a noticeable difference.
