zip439
Thank you for the information; Very glad you have saved the car and it is running again.
I believe you can get the locks working if you replace the central localing air pump locked in the truck.
This may help:
Air Pump Replacement
Hi!
After decoding Sreem and Mcu, the locks are not working cause locks are a part of the Sreem System.
In any case the car is running again.
Next tomorrow steering lock back To it's place and the interior back.
Every Year a lot of problems... 2021 the alternator started To burn.... It was close To the total...
2022 brakepedal went To floor... Abs pump jammed.
2023 RCM.. Repaired and again 2024 a new one.
Only 82.000 km. Staying In a garage for 7-8 monts/Year dosn't make good.
Let’s see, what is the Next problem...
Then replacing EMC and Sreem.
