wing issue with coupe and roadster
greetings,
this is about the coupe and maybe the roadster.
it's about the wing.
i have it uninstalled the wing and removed the electic motor.
the issue is that the limit switches are not being activated.
on the wing their is a shaft the runs nearly the lenght of the wing.
in the center of the shaft is a big gear, on both sides of the big gear their are protrusions that stick out and should make contact with the limit switches when the end of travel has been reached.
i'm having problems with taking the wing apart any further. does anyone know where i can find instructions to remove the shaft in the center of the wing ?? i have downloaded the shop manual but im unable to find further instuctions.
