Re: wing issue with coupe and roadster
when i bought the car the wing didn't work. it was in the down postion.
the fuse (number 16 i think) was blown. i replaced the fuse and the fuse blew the moment i started the car. so i took the wing off, with the wing disconnected the new fuse did not blow. the wing was full of junk, i don't believe it has been working for a very long time. after cleaning and getting smooth movement from the wing i reconnected the wing to the car, the wing was in the up postion. when i started the car the fuse did not blow. when i pressed the "wing down" button the wing moved to the down postion and then the fuse blew. the problem is not the microswitch, strangley enough somehow the "big gear" has slipped on the shaft.
most likely i could create two cam lopes on the big shaft and postion 2 micro switches to the cams but at 95 bucks why bother. i bet i couldn't build the cam lopes for less than 30 bucks and 20 hours labor.
Reason: bad gammar
