Old Oct 27, 2006 | 01:16 AM
HDDP's Avatar
HDDP
Default Re: HDDP you will be proud...
Originally Posted by Dave OH32
using a spacer for autocross is a perfectly fine solution. I wouldn't do it while tracking the car at speed, but at autocross speeds, its fine.
I'll buy that rationality since your speeds are relatively slow and you're not making that many laps. I have no problem with rear spacers for the track, but fronts are a NO NO. IMO.
Originally Posted by soloIIracer
Dave has been running the 245 Kuhmos on the front with no issues. FYI the 245 Kuhmo is the same width as the 225 Hoosier.
I'm really surprised that a 245/40/18 Kumho is the same width of a 225/40/18 Hoosier, I would very highly doubt that. I can tell you from my experience, a 235 or wider Hoosier R3S05, Toyo R1 or Michelin Pilot Sport Cup will not clear the upper A frame bolt with the OEM wheel offset and a -1.85 camber adjustment. A 235/40/18 from those aforementioned tires takes an additional 7mm's to clear the end of the bolt.
And after re-reading Dave's post, I understand now how he's getting the clearance for a 245 tire, he's running a 17" wheel. So, back to my original comment from a few posts ago, a 235/40/18 + width competition tires will not work with the OEM wheels !!! Get your facts straight kid !
