Originally Posted by btwalsh
Hi,
Has anyone of you had a problem with moisture getting into the front headlamps of your UK Crossfire? I have had them changed twice and it's still happening. DaimlerChrsyler are saying it can't be stopped and if it clears after 20 mins when the headlamps are on this is normal. Write to me at
barrywalsh@firenet.uk.net if you want to.
Many thanks,
Barry
I had the same problem from new. Bounemouth dealer did TSB. Have had zero problem since!
Might be worth checking that your dealer is actually applying the TSB and not just fitting new headlamps that all have the same problem.
Best of luck...hope you get it sorted.
