Old Nov 6, 2006 | 07:12 PM
dynamicS's Avatar
dynamicS
Default Re: sema crossfire...
Originally Posted by andrew
the brass tip will eventually come loose from the plug and roll around in the tire. it will turn into a bb form. they have tested many many kits and the bass end cap doesn't cause any adverse affects… nor will it affect the balancing of the tire. if the puncture is larger than the plug supplied... you can use multiple plugs to fill the hole.
I hope your kidding? the brass barb comes loose? well then what's the reasoning behind that?
You can get plug kits at any store. I thought the brass tip was designed with some purpose in mind, guess not?
I would buy one if the brass tips was anchored to the plug material, so that it cannot get ripped out.
