Originally Posted by FPMartinez
$165 is a bit stiff for a filter. Andrew's instructions do not look that complicated. I wonder what the benefit is for the Roadster?
the filter change is cake imo. total time maybe 15 minutes. 2 bolts remove cover... slide clips pull filter out... repeat.
as for the roadster... you need clean fresh air when the top is up... it will offset all that pollution you took in with the top down.
