Originally Posted by ssscott75074
After alignment, camber on the fronts is -0.9 and the rears are -2.1.
I just burned through the factory contis in 11k miles, so I'm more sensitive now to having everything set up correctly.
Does the weight of passengers make the camber more or less negative?
Here are the factory specified ranges for camber based on the OEM. Camber adjustments are based on your driving style. Do some research on camber adjustment from the "Tire Rack Tech Center" online and make your own determination what kind of handling characteristics you require for your driving style.
If you need to adjust the front camber buy the crash bolts from
http://www.chryslerpartsdirect.com for a whole $8.00
DC Spec.
Front: -1.5 to -0.9
Rear: -1.6 to -0.6
