Originally Posted by ssscott75074
I'm more concerned about tire wear than performance. The fronts are on the fringe, and the rears are noticeably out of spec. I've contacted a Mercedes mechanic to look at it. Are the bolts only for the front, or can the rear be similarly adjusted?
Thanks for your help!
Here's what you need if you're racing the car... If it's just to get spec alignment back, I can't help.
http://kmac.3x3design.com/cms/
