Old Nov 15, 2006 | 05:04 PM
HDDP's Avatar
HDDP
Default Re: 18s on the rear?
Originally Posted by dynamicS
Same diameter as stock. Is it possible to go as wide as the rear?
The problem on the front is the upper A frame bolt. You'll have to test the clearance with the tire mounted. You can put spacers on the front, but I do not recommend it if you are going to do any HARD driving (track stuff).
