Old Nov 16, 2006 | 06:37 PM
stryfox's Avatar
stryfox
Default Re: Remote Power windows using key fob...?
I have put power window automators in some cars so sure why not. The problem would be using the factory remote as it only has 3 buttons.
If you set it to the unlock the windows would go down every time you unlocked the car.
If you don't feel the need foe a panic button you could probably tap into that.
You would however need to disconnect some of the factory alarm systems.
With an auxiliary remote it would be pretty straight forward.
You could even set it to just crack the windows also.
