Re: losing air from rear tire
You may also check the valve core (inside the valve stem) to make sure that it is seated properly. Squirt some soapy water into it and around the stem and see if it blows bubbles. If not, then it is definitely from the tire somewhere. Slow leaks like that can be hard to find.
