Re: losing air from rear tire
Good points!!! My thoughts are that if it is leaking from the stem, then air pressure escaping is going to keep the moisture from entering. Either way, I would dry it out before replacing the cap. I wouldn't want it exposed to constant moisture but I'm not sure how else you would check it without exposing it to some temporarily.
