Old Nov 22, 2006 | 12:31 PM
Extensive's Avatar
Extensive
Default Re: Oil Change & filter Change .. Cost of doing it question ???
Originally Posted by FPMartinez
There are a number of threads you should probably read on this forum. Just do a search on "oil changes", and you will get familiarized with the options. Many here do their own. The reason it's expensive is b/c it takes about 8.5 quarts of Mobil One. Even doing it yourself will cost about 60 - 70 $$.
If I wanted to buy the filter alone, and have the oil changed at a quickie lube... would that cut cost? How much is just the filter? Or would a quickie lube have an aftermarket standard filter that will work...
