Oil Change & filter Change ... Cost of doing it question ???
Nov 22, 2006 | 12:39 PM
permalink
Aug 2006
13,396
26
Crystal Lake, IL
Re: Oil Change & filter Change .. Cost of doing it question ???
Quote:
Extensive
If I wanted to buy the filter alone, and have the oil changed at a quickie lube... would that cut cost? How much is just the filter? Or would a quickie lube have an aftermarket standard filter that will work...
It really comes down to the level of confidence you have with the quick lubes. I don't know what they charge but can assume it will be over $100. It's actually very easy to change the oil on the XF if you buy the oil vacuum/pump as the filter sits on top. I would consider going this route even though I stopped changing my oil many years ago, because it's so easy, but I have a lifetime of oil changes on my XF from the dealer.
I really encourage you to read the threads on this topic. There are many opinions, and tips especially around the oil vacuum option.
View Public Profile
Send a private message to FP
Find all posts by FP
