Old Nov 22, 2006 | 12:46 PM
Extensive's Avatar
Extensive
Default Re: Oil Change & filter Change .. Cost of doing it question ???
Originally Posted by FPMartinez
It really comes down to the level of confidence you have with the quick lubes. I don't know what they charge but can assume it will be over $100. It's actually very easy to change the oil on the XF if you buy the oil vacuum/pump as the filter sits on top. I would consider going this route even though I stopped changing my oil many years ago, because it's so easy, but I have a lifetime of oil changes on my XF from the dealer. I really encourage you to read the threads on this topic. There are many opinions, and tips especially around the oil vacuum option.
What about the filter? Is it standard, as in an oil changing shop should have it in stock?
Thanks.
