Re: '07 Nasa Pro Racing Schedule
If you use the injectors off the SLK32 engine and leave everything else (engine management, intake, sensors, etc) alone on the long block and just integrate the mechanicals, then you should be fine.
If you start introducing computer boxes, main sensors, etc. then you may get into compatibility problems.
Good luck... and keep us posted!
