Old Nov 27, 2006 | 05:47 PM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: pics of the SRT on the dyno
My dyno run was taken on an All Wheel Drive dyno (Mustang make) with both sets of rollers connected with a belt system. I'm sure that even in Two Wheel Mode, that the calculations are a little off as the drag of the other rollers may not have been taken into account.
I'm now of the opinion that the Auto-Stick versions don't get the 5,000 RPM limiter kick-in like HDDP's and others. It may be an engine protection feature that senses the front wheel speed and then determines whether the engine rpm is too high. Derek tried with the ESP fuses pulled at the track and still had the 5,000 RPM drop-out, so I think it's only on the Manual transmissions.
Would be interesting to know if you could take the Auto-Stick ECU and put it in a Manual Transmission vehicle and get rid of that 5,000 RPM drop-out.
Cheers!
