Originally Posted by MMZ_TimeLord
I have installed a Becker 6-Disc changer and ran the cable myself. It fits nicely in the 'first aid recess' under the cargo area. Only 'mod' I had to do was deepen the hole itself and pad it with soft foam.
Running the cable was a chore, but can easily be routed next to the existing wiring along the passenger side floor, out the front of the carpet and then into the dash to the center for the head unit. Make sure you get the 20' or 25' connection cable.
Cheers!
Could you give me the part number and price of the CD changer? I just installed factory nav and I want a CD changer so I can leave the nav disc in the headunit. Did it plug into the empty slot on the back of the headunit above the factory harness plug? Thank you.
