Old Nov 29, 2006 | 07:28 PM
  #504 (permalink)
SteveUSMC's Avatar
SteveUSMC
Default Re: Sprint Booster - A "Must-have"!
Originally Posted by PAULW
Ok the Sprint Boosters arrived late this afternoon so here goes,
#1 - rdotson - Thank you for pioneering this thing and such great instructions for installation. Once again Thank you.
#2 - I have read all the ideas and doubters but all I can say is WOW.
I have reset mine a bunch of times but resetting your computer isn't anywhere close ...
#3 - Thanks to rdotson I installed mine in less than 15 minutes in this order, pictures
are here: https://www.crossfireforum.org/galle...ry.php?cat=574
1. Remove the lower nut cap.
2. Remove the 10mm nut.
3. Remove the washer, a magnet helps.
4. Remove the pedal, lift the bottom pulling out and pull it out of the upper bracket.
5. Unplug the tps cable from the sensor.
6. Plug the tps cable into the Sprint Booster.
7. Plug the Sprint Booster cable into the tps sensor.
8. Reinstall the pedal assembly.
9. Go for a test drive, you WILL SMILE !!!
This is a short (maybe long) review and for non believers... OK ...
My car will now bark the tires from a standstill and put you back in the seat and I mean instantly, NO HESITATION, RIGHT NOW!!!
Don't believe it ? Try it, you will believe !
Wow that sure seems like a lot more work than i did, maybe its just because i have small hands or something but i put it in without undoing anything you can just barely reach it and wiggle it loose, plug the booster in and wiggle it back on, presto...took about 3 minutes.
