Old Nov 30, 2006 | 02:13 PM
HDDP's Avatar
HDDP
Default Re: Outside Temp Gauge Question
Originally Posted by Fcope
Despite the fact that the weather has been in the 70's here for the past few days the temp display on my dash shows -36 degrees F. Any thoughts on what could be causing this? I suppose I could take it into the dealership, but would rather avoid doing so if there is a simple solution.
Your temp sensor is either disconnected or not functioning... when it dies it reads -36 ... check the sensor to see if it has been damaged / disconnected... it's a little black plastic pointy nub that is attached behind the front bumper on the driver side just behind the plastic grate, inboard of your fog lamp... Wish I had a picture for you, but mine has long since been removed...
If it is damaged or dead, you can buy a new one and install yourself for a few bucks... http://www.chryslerpartsdirect.com
