most HID kits use 35 watts while your original bulbs took 55 watts ... this translates to lower amperage draw which the system is confusing for the bulb out ... i just wish i knew what size resistor you need inline to the power cable to correct this.
honestly i would not feel very comfy having a resistor inline to that power line however as it will generate alot of heat which can lead to big trouble ... i'd rather pull the bulb for the dummy light in the gauge cluster and know i have a system that works perfectly fine ....
just my opinion on that tho...
