Re: HID problem...
you have a bad connection somewhere that is more likely causing the problem ... if the kit you have required you to insert bare wire leads into a socket then plug it into the original harness (90% of the kits like mcculloch do this) then start at that point cause chances are thats where it is not making proper contact... good luck.
