Re: CTD-Germany Custom Front Grill Group Buy
regarding the mesh:
the dimensions of this mesh on the picture is 8mm by 8mm each square of the mesh. we can also insert a 7, 1mm by 7, 1mm mesh. exactly the same mesh (8mm mesh) is used in the jaguar xjr grilles and they don't have any problems with rocks.
the 300c grille should have the same size. maybe someone can check it, so you can compare the sizes.
a price is not set yet. i must check out how much painting is, if i have the final version of the grille.
tino
