Re: Pros and Cons of changing wheel sizes
flow, you damaged your e-brake assembly... as i did mines... after i repaired the spring i bent in the assembly i ended up measuring the stock bolts with the stock wheels and just made my new bolts on my new wheels have the same length that goes in the hub... problems gone...
