Old Dec 25, 2006 | 11:41 AM
jonnyangel04's Avatar
jonnyangel04
Default Re: HID Light Coverage
i have a 6,500k kit and looking at that also they don't look like there in the bezel all the way. The question is, can you detach the bulb from the power and ballast cord or is it plug and play with the cord fused to the bulb? I bought a cheaper kit and the bulb was fused to the cord I ended up having to take the bumper off and work that way. I also had to fab up my own h7 clip and take a day or two of my time to get them to sit right. Assuming you have the right bulb and assuming your working with the headlight assembly still attached. You're trying to jam your hands in what little space they give you to fit the bulb. It looks like you have it in and your bringing down the clip and its holding it in there but it’s not as far in as it should be. The only reason I feel this way is when I turn mine on without adjusting anything there is no yellow hue coming out the sides and its just pure light right out of the projector. I'm not doubting that you can't put in a headlight and please don't take this the wrong way I'm just trying to help you troubleshoot the problem.
