Old Dec 26, 2006 | 12:09 PM
HDDP's Avatar
HDDP
Default Re: Member HELP ASAP --- DYNO RESULTS
Originally Posted by stryfox
The +10 points on tire width seems a bit much. How much wider are you tires? Stock width may be better on the next set instead of the +10 if you can get a race tire in the factory size.
I'm sure you thought of this but who knows maybe you overlooked it.
And if they weigh the car with the driver you could always eat at McDonald's first! lol.
The 2007 rules are kinda bad for certain cars. Since the Crossfire is Base Classed in TTE they have determined that those cars in TTE should have 235mm tires regardless of the OEM tire size. And every 20mm increase carries +5 points. I'm running 275's on the rear, so I get dinged +10. I could go back to the 255's, but with all the other points assessed to me this year, it doesn't really matter.
The only other thing I'm hoping to do is get a waiver since the car puts such low HP to the wheels. Either that, or I'm just going to have to figure out some additional mods to get the HP up.
