Originally Posted by Electric Messiah
Any way I can turn off the seat belt alarm without disabling anything else?
~ you sure can...
to eliminate the chime and nothing else… you need to cut the single wire to the seat belt chime. this also will eliminate the seat belt symbol on the dash instrumentation.
you can access the wire from the back side of the seat (put seat all the way forward & up)... the long wire harness is clipped onto the back of the lower seat edge. undo the 2 clips that attach wire to the frame (no need to pull seat)... cut back the black plastic sheathing and expose
brown wire... snip it and you are good to go.
no chime for me.
