Old Jan 4, 2007 | 12:58 AM
Electric Messiah's Avatar
Electric Messiah
Default Re: Silly question... but here goes. Doing a 180.
Originally Posted by +fireamx
E.M. If I understand you correctly, you want to do a "180" by turning the front wheels as far as they will go, and then "smoke" the rear tires while the whole car "pivots" around until it is facing the opposite direction.
Before that would be possible, I think you would have to pull the fuse on the traction control, since it never really is turned off.
Plus (being an automatic) you may have to "power brake it" to break the tires loose too.
Thanks.
But not entirely true on the traction control. All you have to do is turn off the power traction switch. Nothing to pull or modify. The rear tires will break traction with the switch engaged. Unfortunately, you do have to make a sharp turn to have them break traction...
I'm wanting to do a controlled pivot to minimize my fishtailing. I'm assuming I'm just going to have to practice.
As for the power brake, how do you do this?
