Re: Occasional rough idle or engine stumble
You should check your air filters, maybe they are plugged? Also you might have air leaking past the seal on the MAF. When I took my entire intake apart I coated all the rubber seals with silicone grease. Maybe someone didn't install the air cleaner and MAF properly?
